Alert Id Max Character Limit
I’m trying to find out what the max character length of the Alert Id is. I’m not seeing anywhere in the docs that specifies character limit. Any help would be much appreciated. Thanks.
Hi Max! Could you clarify which parameter you’re referring to when you say “Alert ID”?
If you’re referring to the title or summary of the alert, the maximum character limit for that is 1024 characters, which is mentioned in our documentation here.
I hope the above helps! Let me know if you have any other questions.
Cheers,
Cassie Champagne
Technical Support Specialist
PagerDuty Support
